CLIPPER not working
  • Jul 22, 2024 3:37 PM UTC
  • 8 replies
  • 304 views
vimva679
Forum|alt.badge.img+11
It was all working properly just few days back , today clipper is just crazy.
I have IFC 3D Model and Excel file with XYZ coordinates, all i trying to do is clip all those coordinates are  inside / touching the boundary of 3D Model.
ctredinnick
Forum|alt.badge.img+22
  • Jul 23, 2024 4:29 AM UTC
Maybe try a Aggregator + BoundingBoxReplacer (3D) after your excel coordinates. What you have will fail to clip because you can’t clip with points.
Or you have it around the wrong way and your IFC model needs to be the clipper.
vimva679
  • Jul 23, 2024 12:00 PM UTC
Here are possible 2 scenarios , in one example i am able to clip and in another it fails.
PASS
FAIL
With Fail i have tried to use IFC model and intersect with Excel coordinates and its work well. ….! It only here in FME that its not clipping :(
nielsgerrits
Forum|alt.badge.img+67
Are the features entering the clipper areas? This can be checked by using a GeometryFilter. Do the areas have an area? Can test this usingt the AreaCalculator. Are the areas correct? The GeometryValidator can check this.
If you check the rejected features, what is the fme_error saying?
Anyting in the log?
vimva679
  • Jul 23, 2024 3:49 PM UTC
Are the features entering the clipper areas? yes the Clipper is an Area (3D Room)
This can be checked by using a GeometryFilter. Do the areas have an area? Yes it does have an area.
Can test this usingt the AreaCalculator. Are the areas correct? Yes it does have area
If you check the rejected features, what is the fme_error saying? The rejected feature are okie . No problem with that its the ‘Outside’ ….all those 594 feature (XYZ coordiantes ) are inside the 3D Room and i have check using Navisworks and AutoCad Civit 3D , by overlaying each other.
nielsgerrits
Is your issue that all features are outside?
Are the coordinate systems the same? What CRS have the Excel points? CoordinateSystemSetter.
Are the units the same? Designs can be created in millimeters.
vimva679
  • Jul 24, 2024 3:15 PM UTC
The issue is that all the features are outside, that’s correct.
I agree with you @nielsgerrits its now something do do with Coordinates that both items are in. Now i may need help or guidance how to get it all right.
this is now i have checked
the 3D Cube is ad below
This below 676 point inside the 3D cube
vimva679
  • Jul 24, 2024 3:25 PM UTC
this is topic that i never got it right or understood, Coordinate Setting, here are some basic question
  1. How to know in which coordinate system features are ?
  2. If there is no coordinate system set, how to get both feature into correct coordinate system ?
nielsgerrits
If you remove the coordinate system in both streams (CoordinateSystemRemover) it might be enough to get it to work.
I’m no expert in this topic so hard to write something that makes sense and be sure it is correct. Reverse engineering a coordinate system is hard. I usually just try what I think it is and if it does not align, it’s not correct.
If you open the 2 streams in one inspector, you can validate this (does one set lies on top of the other, as expected) just connect the 2 sources to 1 inspector.
