Changing attribute types of dataset
  • Feb 27, 2019 8:51 AM UTC
  • 986 views
jugoslaviaa
Hello,
I have a street centerline data set which has street width information. I would like to buffer the lines by using GeographicallyBufferer based on the width information (to be more precise sum(div(@Value(SURFACEWID),2),16.4042) is my buffer size). However I can not because the street width attribute has long type. Is there any way to change it so that I could use the value of the attribute and use aritmetics with it.
Thanks in advance.
Best answer by david_r
If you need to change the data type of an existing table, you have a few options:
  • Use the data format administration tool (ArcCatalog, PgAdmin, etc) to try and change the data type, when possible
  • Use FME and copy the data into a new table with the modified data type, then delete the old table.
  • Recreate the table from scratch with the correct data type, then reload the data.
  • Feb 27, 2019 9:04 AM UTC
jugoslaviaa
  • Feb 27, 2019 9:17 AM UTC
Thanks for the answer @david_r. What do you mean by copy data into new table? Which transformer does allow me to do that?
  • Feb 27, 2019 9:18 AM UTC
No transformer necessary, just Reader -> Writer.
jugoslaviaa
  • Feb 27, 2019 10:55 AM UTC
thanks @david_r! I went for option 2 and it does work.
