change vertex z value through python caller
  • February 10, 2014
  • 24 views
venu
Forum|alt.badge.img+5
I have a polygon in that i need to change z value for 3 and 4 vertex.
Please can any one help me how to do in python
Thanks in advance
  • February 10, 2014
have a look at the Python API documentation, it is installed with FME under <FME>/fmeobjects/python/apidoc/index.html
You can do something like:
coords = feature.getAllCoordinates()
if feature.hasGeometry() and len(coords) >= 4 and feature.getGeometry().is3D():
    coords[2] = (coords[2][0], coords[2][1], new_z_value1)
    coords[3] = (coords[3][0], coords[3][1], new_z_value2)
    feature.resetCoords()
    feature.addCoordinates(coords)
Be careful if you have multipart and/or aggregate geometries, though.
David
venu
  • February 12, 2014
Please can Explain how to compare the vertex z value.I don't know python codes, but i can understand if you explain.
  • February 12, 2014
Hi Venu,
Assume that dimension of input polygon was 3D and you have retrieved coordinates list with this expression as David suggested.
"coords[i]" (i is 0-based index of vertices) represents a tuple which contains (x, y, z) of vertex(i).
Therefore "coords[i][2]" represents z value of vertex(i), you can compare it to other value in the script.
Just be aware that element index of Python list and tuple is 0-based. e.g. index of the 3rd element of list or tuple is 2 (not 3).
Takashi
