Change the value of an attribute depending on the value of other attribute
Hello,
I would change the value of an attribute in a table depending on the value of other attributes group of records. Concrete example :
INPUT
NameColorAreaAAAYellow150AZARed56BDEGreen29ABABlue298CDEGray8AZABlack76ABAOrange84BDEPurple162AZAWhite65
Sort by "Name" and "Area"
NameColorAreaAAAYellow150ABABlue298ABAOrange84AZABlack76AZAWhite65AZARed56BDEPurple162BDEGreen29CDEGray8
and give the same Color value as the record with the highest area
OUTPUT
NameColorAreaAAAYellow150ABABlue298ABABlue84AZABlack76AZABlack65AZABlack56BDEPurple162BDEPurple29CDEGray8
Thanks for your help.
jdh
Forum|alt.badge.img+28
  • January 7, 2020
One way would be with conditionals and adjacent feature handling.
If your data is sorted as per the second example, then an attributeCreator to change the value of Color.
Forum|alt.badge.img+39
  • January 7, 2020
This workflow should do what you want
The AttributeRemover and AttributeKeeper aren't strictly necessary as you could set Conflict Resolution to Use Supplier in the FeatureMerger instead
  • January 7, 2020
@pedro I've attached the example workspace to illustrate @jdh 's solution (2019.1): adjacentattributes.fmwt
More on the Adjacent Feature Handling in the AttributeCreator documentation under the section Advanced Example: Using Multiple Feature Attribute Support
bwn
Forum|alt.badge.img+26
  • January 8, 2020
I would similarly use essentially the same solution shown by @ebygomm. The key is DuplicateFilter, what it does is take the "first" feature within a Group and sends that to the Unique Port, and any others within that group gets sent to the Duplicate Port.
If you send a Sorted table, then DuplicateFilter will automatically then take the Top/First result in each Name group, and then the Top/First Color can be joined back into the original table with a FeatureJoiner or FeatureMerger (FeatureJoiner tends to work faster for large datasets).
bwn
  • January 8, 2020
Alternatively InlineQuerier can do it in one step. If you send the unsorted, raw table to InlineQuerier and say name the table "ColorTable" then using this as the SQL Expression for the Output within the Transformer will work:
SELECT A.Name,
(SELECT Color FROM ColorTable WHERE Name=A.Name ORDER BY Area Desc LIMIT 1AS MaxColor,
A.Area
FROM ColorTable A
Essentially it makes an Attribute "MaxColor" as a value derived from Subquery that sorts by Area in Descending order within its Name Group, and takes the top row as the Color result (this is what "LIMIT" does)
Input Table
Result Table
