change the coordinate system
charlesdollat
Forum|alt.badge.img+3
I would like to change the coordinate system in Lambert 93 EPSG: 2154 for shapefiles.
But i can't find the good one in the coordinate system Gallery. (i have a tamplate to compare(PRJ file))
Capture do you know if i can add this .PRJ to reprojector maybe ? because i need to change a lots of files
Thanks,
Charles.
dustin
Forum|alt.badge.img+31
  • January 3, 2023
You can add custom coordinate systems. This link may be helpful. About Custom Coordinate Systems (safe.com)
egge
Forum|alt.badge.img+14
  • January 3, 2023
Bonsoir Charles,
From the screendump you are showing we can see that FME supports the Coordinate System with the EPSG code 2154, which is Lambert-93 with RGF93 (Reseau Geodesique Francais) datum for the whole of France métropolitaine/le territoire européen de la France/l'Hexagone.
So, why would you not use this one in your case?
If you want to reproject your shapefiles from one Coordinate System to EPSG:2154 you can use the Reprojector transformer. It might also be the case that the data is already in the right projection but without the Coordinate System explicitly set. In that case you could use the CoordinateSystemSetter transformer to assign the French coordinate system to your features, without modifying the geometry or the coordinates.
Is this an answer to your question?
