Change some Z-Values for every Vertex (Line, Area Features)
I have a FileGeodatabase and want to change some Z-Values from Line and Area Features (with all kinds of Geometry).
For Example i just want to set all Z-Values which include 99 or 0.153 to 0 and keep all other Vertex Z-Values.
The Elevation Extractor gave me only the first Z-Vertex-Value to manipulate. The 3D- Forcer changes every Z-Value. The Offsetter is not the right one either.
I tried the Coordinateextractor an Coordinatereplacer but i dont know how to put my changes to every list element.
I dont want to destroy the geometry (with Chopper or something else). I just want to add these simple changes for the height.
My further suggestion are maybe some FME-Feature-Functions tricks with Expressionevaluator or a Python Skript?
Can you help me or give me hint?
Thank you
Richard
Forum|alt.badge.img+54
  • May 20, 2020
No idea if it will work on the more complex geometries but you could potentially do something like this
import fme
import fmeobjects
def shiftz(feature):
    zshift = [0.153,99]
    coords = feature.getAllCoordinates()
    for i in range(len(coords)):
        if coords[i][2] in zshift:
            coords[i] = (coords[i][0],coords[i][1],0)
        else:
            coords[i] = (coords[i][0],coords[i][1],coords[i][2])
    feature.resetCoords()
    feature.addCoordinates(coords)
debbiatsafe
Forum|alt.badge.img+24
A method that doesn't use Python would be to use the GeometryExtractor (extract as GeoJSON), use Regex to replace 0.153] or 99] with 0] in the StringReplacer, and then GeometryReplacer. You would have to check incoming features are 3D, otherwise you may replace a vertex's y-value.
