casting to integer in geojson
Is there any reason that FME would not cast a value to an integer using xs:int(value)?
i keep getting:
"xs:string": invalid value for cast/constructor: can not cast to "xs:int"
the incoming value is a 12 digit number from a GML file with type: xml_int64
i try it without the cast and the JSONTemplator works but it comes out as a string when i need it as an integer.
Best answer by david_r
Try using "xs:integer" rather than "xs:int".
The difference is that
xs:int
 is a signed 32-bit integer, while
xs:integer
 is an unbounded integer value.
Twelve digits exceeds the 32-bit integer range: 2147483647 to -2147483648.
  • May 11, 2018
xs:int
xs:integer
Thank you, didn't realise there were two different ones.
