Cannot export the right folder structure through fanout
  • Aug 11, 2023 7:15 AM UTC
  • 7 replies
  • 106 views
Dear Sir/Madam,
I would like to export fbx to cesium tiles.
My FBX model structures are follow
11-NE-12A\\BXXXXXX
11-NE-17A\\BXXXXXX
I would like to export at the same folder structure in Cesium tiles.
It gives me an error when I use the fanout expression. And now, I only able to create the following folder structure.
11-NE-12A\\BXXXXXX\\BXXXXXX
11-NE-17A\\BXXXXXX\\BXXXXXX
May I know how to fix it?
I have attached my sample data and fmw in this email. And I hope some experts can give me a hand.
Thank you
Anybody could give me a hand? I am really appreciated it.
tomfriedl
Forum|alt.badge.img+14
  • Aug 14, 2023 9:15 AM UTC
Output is going to:
[fanout] + [feature-type from writer]
In your version:
@Value(path) + @Value(fme_basename)
11-NE-12A\\B391712021101063A0 + B391712021101063A0
better is:
$(DestDataset_CESIUM3DTILES)\\@Value(_tilename) + @Value(fme_basename)
[your Outputpath] + 11-NE-12A + B391712021101063A0
Output is going to:
In your version:
better is:
Thank you for your assistant, Tom. I am really appreciated it.
However, if I do it your way "$(DestDataset_CESIUM3DTILES)\\@Value(_tilename) + @Value(fme_basename)"
It is gonna be like this.
However, I would like the folder structure to be like this. "11-NE-12A\\Bxxxxx".
I tried to use "$(DestDataset_CESIUM3DTILES)\\@Value(_tilename)". It shows an error for some reason. Do you have any idea how to fix it?
Thank you very much.
tomfriedl
  • Aug 15, 2023 7:46 AM UTC
You read my post wrong :-)
try:
[fanout] = $(DestDataset_CESIUM3DTILES)\\@Value(_tilename)
[feature-type from writer] = @Value(fme_basename)
try:
Sorry for the misunderstanding.
Is this how I should set for "feature-type from writer"? I am not sure why I got this error though. image.pngimage.pngThank you and sorry for all the questions.
tomfriedl
  • Aug 15, 2023 8:25 AM UTC
Sorry, restart:
[Destination Fanout Directory] = $(DestDataset_CESIUM3DTILES)
[fanout] = @Value(_tilename)
[feature-type from writer / Cesium 3D Tileset Name] = @Value(fme_basename)
Sorry, restart:
Hi Tom,
So this is what my setting looks like
It is really interesting that after I set "[Destination Fanout Directory] = $(DestDataset_CESIUM3DTILES)"
It will automatically switch my path to this. And the error "CESIUM3DTILES writer: An error has occurred. Check the logfile above for details" pop up.
image.pngSorry about that.
