Can you run a SQLExecutor transformer that takes a string as a parameter and uses it as part of the SQL statement to be executed?
  • Jul 27, 2021 12:05 PM UTC
  • 123 views
plynn
Forum|alt.badge.img+10
I need to run a sql statement to determine if my workspace should run. If the sql statement returns any records, then I need to terminate the flow. If nothing is returned then it is okay to run the workspace. I would like to pass in a user parameter as a string to be used in the sql statement. Is this possible?
Best answer by redgeographics
In short: yes, you can build the query using attribute values, parameters etc.
You should probably look into the NoFeaturesTester to check if nothing comes back too
Forum|alt.badge.img+63
plynn
  • Jul 27, 2021 12:20 PM UTC
Thank you. I have added the NoFeaturesTester and it seems to be working well.
