Can we migrate the data directly to Esri UN model geodatabase instead of migrating to Asset Package GDB, using FME Desktop?
  • Jun 7, 2023 8:00 AM UTC
  • 69 views
nitinshahane
Forum|alt.badge.img+7
trentatsafe
Hello @ni3​
You can move data to the Esri UN data model once the UN is fully published/versioned. To do so, you have to use the Esri ArcGIS Portal Feature Service Format. This will allow you to read/write to the UN including the Branch Version of your choosing.
