Can't correctly recognize the Geometry column
  • Sep 3, 2019 9:48 AM UTC
  • 11 replies
  • 271 views
Hi
When I created my Reader, I can read all my data and especially my geometry column but this column doesn't display . I try different coordinate system but it does not match. Same issue.
What's wrong with this Reader ?
Thanks
Best answer by nielsgerrits
I think you read a PostGIS table with a PostgreSQL reader?
nielsgerrits
Forum|alt.badge.img+67
  • Sep 3, 2019 10:06 AM UTC
gio
Forum|alt.badge.img+15
  • Sep 3, 2019 11:40 AM UTC
yeah, looks like wrong reader(?)
You could of course use geometryreplacer on the string.
  • Sep 3, 2019 12:34 PM UTC
@gio : No I didn't try the geometryreplacer Transformer.
@nielsgerrits : yes you're right. (I read a PosGIS column type from a PostgreSQL reader. My data are in Psotgresql database )
nielsgerrits
@jerome "PostGIS is an extension to the PostgreSQL object-relational database system which allows GIS (Geographic Information Systems) objects to be stored in the database. PostGIS includes support for GiST-based R-Tree spatial indexes, and functions for analysis and processing of GIS objects." - https://postgis.net/docs/manual-2.5/
PostgreSQL non spatial --> PostgreSQL reader
PostgreSQL spatial --> PostGIS reader
@gio What settings do you need to get the GeometryReplacer to work with the geometry column? When I read a 3D point (0.5,0.5,0.5) with the PostgreSQL reader the geometry value is:
0101000080000000000000E03F000000000000E03F000000000000E03F
Using the GeometryReplacer with WKB I get:
2019-09-04 06:50:08|   0.5|  0.0|WARN  |Invalid WKB encountered.
This is in 2019.1.1.0
itay
Forum|alt.badge.img+19
  • Sep 4, 2019 6:11 AM UTC
@nielsgerrits I belive you need to set it to OGC Well Known Binary (not tested)
nielsgerrits
@itay Yeah thats what I thought but this gave me the "Invalid WKB encountered." warning.
itay
  • Sep 4, 2019 6:52 AM UTC
oops...I see that now...
  • Sep 4, 2019 7:17 AM UTC
@nielsgerrits: I had installed the posgis extension with Postgresql and it worked well. But I didn't think it was necessary to change the type of Reader. I didn't know OGC WKB.
gio
  • Sep 4, 2019 8:40 AM UTC
@jerome
Geometryreplacer: Hex Encoded OGC Well Known Binary
(The letters in the string indicate it is hexadecimal.)
Greets
  • Sep 4, 2019 9:59 AM UTC
You're right . I used the wrong reader: my data was in a Posgresql database format but my column was in Postgis. So with the Postgis format I can now read my geometry data.
Thanks.
nielsgerrits
@jerome
Greets
Learned something today, thanks!
