Can Chart Generator axis values be displayed in scientific notation?
notmyname
Participant
Hello,
I am using the chart generator with some small numbers to make a scatterplot. I can't figure out how to display the axis values in scientific notation. See the example chart generator output image below using some made up values. The Y axis values range from 1.0e-3 to 1.0e-9. I would like to change the axis values to scientific from decimal.
Thanks for the help
Sheet1
Best answer by daveatsafe
Hi @David Birkigt​,
You can use the StringFormatter transformer with a Format String of e to convert your numerical values to scientific notation strings before the ChartGenerator. The ChartGenerator will interpret these correctly and create a chart similar to this:
Screen Shot 2023-03-01 at 3.15.22 PM
daveatsafe
Forum|alt.badge.img+19
  • March 1, 2023
Hi @David Birkigt​,
notmyname
Participant
  • Participant
  • March 2, 2023
daveatsafe wrote:
Hi @David Birkigt​,
Appreciate the help. I messed around with e and TCL (not enjoyable) for a bit. I am not quite getting the format I want so I'll probably pursue another charting option.
Thanks
