Calculate the field value based on another field.
  • February 17, 2019
  • 8 replies
  • 102 views
Hi FME Experts,
I have a field, I would like to create a new field based on duplication of the records in this field . as the attached image, is there any way to do that?
Thanks in advance
Best answer by takashi
OK. You can use the Counter with a counter name containing the user name.
e.g.
  • February 17, 2019
Do you need to get the number of records for each User Name? That is, should you get 3 for A, 1 for B, 6 for D in your example?
  • February 17, 2019
@takashi
No, I want the result to be like the (user_id) field in the screenshot
  • February 17, 2019
e.g.
  • February 17, 2019
e.g.
@takashi
Thank you, what about if I want to the output to be (00001,00002,.....,00026), in which the number of digits to be 5.
  • February 17, 2019
e.g.
Have a look at the StringFormatter.
  • February 19, 2019
Thank you @takashi ,
Could you please assist me it this?
I am trying to extract the Max value from a field then use it in calculating the value for another field (sequence).
But it gives me the below error
  • February 19, 2019
If you intend to newly create the attribute "PID" in the AttributeManager with such parameters setting, try exposing "PID" with the AttributeExposer beforehand.
However, I think you can do it with the Counter (Count Start: 150266) more easily.
  • February 19, 2019
The counter was the alternative solution but should be a more effective way, which the user no need to but the max value from his end.
should be a way to extract the max value (statisticscalculation) , then take a max value then use it to calculate the new field.
