Calculate overlapping area from other feature class
  • May 19, 2020 3:25 PM UTC
  • 284 views
arnovananrooij
Forum|alt.badge.img+5
Hi community,
I have something very simple so it seems, but I can't figure out how it's done. I have area features A and area features B. I would like to calculate an attribute per feature from A which contains the calculated from the overlapping feature B. This should be very simple and it normally is. I would use the Clipper en calcultate the areas comming from the inside port. Or I would use the AreaOnAreaOverlayer and test the number of overlaps > 1.
The problem is that within A features can have overlap. Features B don't overlap themselves. So some area's of B have to be calculated per overlapping feature A. The Clipper doesn't give me overlapping areas and in the AreaOnAreaOverlayer I can not distinct A from B.
Anyone any idea how to solve this?
Greetings,
Arno
Best answer by danilo_fme
Hi @arnovananrooij
I suggest you to use the custom transform MultiClipper and after AreaCalculator.
Thanks in Advance,
Danilo
danilo_fme
Forum|alt.badge.img+58
  • May 19, 2020 3:40 PM UTC
Hi @arnovananrooij
Thanks in Advance,
Danilo
arnovananrooij
Hi @arnovananrooij
Thanks in Advance,
Danilo
Thanks, that worked like a charm! Didn't know about the MultiClipper.
danilo_fme
  • May 19, 2020 5:29 PM UTC
Excellent @arnovananrooij thanks for feedback
