Bulk Renaming of Files - Not Sure Why It's Not Working
  • Nov 2, 2021 9:42 PM UTC
  • 193 views
stefan_kutac
Forum|alt.badge.img+5
Hello FME Community! Year long learner, first time poster, please go easy on me.
I've been trying to add a prefix to all files within a directory. I have searched the forums for answers, and have tried a few different suggestions from previous posts but for some reason, my files don't get renamed.
In this example, I would like to add "2022-" as a prefix to all filenames in a folder.
So far, I have used the "Directory and File Pathnames" Reader with the following settings:
01-ReaderNext, I have used the Attribute Manager to change the filename properties:
02-AttributeManagerFinally, using the File Copy Writer to put the files into the same directory:
03-WriterI can't figure out which settings may be wrong or not completed properly. Thanks in advance for any help or tips!
Stefan
https://community.safe.com/s/question/0D54Q000080hKw8SAE/quick-way-too-rename-files-for-noobs
Forum|alt.badge.img+54
  • Nov 3, 2021 9:11 AM UTC
You need to set the filecopy_source_dataset, filecopy_dest_dataset and filecopy_dest_filename as described in the answer you've linked
These are the attributes that are important for the filecopy writer, path_filename is not used
mark2atsafe
Forum|alt.badge.img+59
@ebygomm​ has the correct solution here - but to illustrate it I made this one of my question-of-the-week and added it to a video here: https://youtu.be/uyF7MEuBdK0
