Bug with the transformation of LAS file to Cesium 3D tiles
  • Feb 25, 2021 3:55 PM UTC
  • 11 replies
  • 417 views
Hey everybody,
I'm currently trying to transform LAS file into Cesium 3D Tiles with FME Workbench.
Las file is provided by an Agisoft Metashape project with EPSG:3945 coordinates. I would like to transform this points cloud into Cesium 3D Tiles with EPSG:4326 coordinates.
I can't use Cesium ion for my project.
Unfortunately, I obtain this strange result. First screenshot is the original file and the second one transformed file.
Has anyone run into the same problem ? Can someone help me to handle it ?
Have a nice day !
daraghatsafe
Hi @thomaspetit​ if you inspect the LAS data in the Data Inspector and look at the feature information are the x, y, and z components set to Real32? If so you could use a PointCloudComponentTypeCoercer to change them to Real64. I had this issue with an E57 file but it may help with LAS.
  • Feb 26, 2021 12:38 PM UTC
Thanks for your answer, I tried a lot of things without any concluant results.
Whatever the way, it leads to the same warning :
daraghatsafe
@thomaspetit​  Can you provide the workspace?
Here is it
  • Mar 19, 2021 12:59 PM UTC
Do you see what's going wrong ?
daraghatsafe
Hi @thomaspetit​ sorry for the delay, yes I can see the issue, can you provide the LAS file also?
Thanks, Daragh
Thanks, Daragh
I can't send you the original file but here is a wetransfer to a similar file : https://we.tl/t-kQEiKLSBy5
Thanks, Thomas
daraghatsafe
Thanks, Daragh
Hi Thomas,
So looking at the documentation for Cesium 3D Tiles, FME does not support the writing of point clouds. So a workaround to this is to create a surface of the point cloud and drape the appearance over it. Please also so see these two articles for an explanation on some of the transformers that I used.
https://community.safe.com/s/article/creating-a-raster-from-a-point-cloud
https://community.safe.com/s/article/point-cloud-to-3d-terrain-model-with-buildings-dwg
I have attached the workspace so you can see if it works for you.
Thanks, Daragh
Thanks, Daragh
Hi Daragh,
Thanks for all your help !
lauriadv
  • Oct 22, 2024 7:39 AM UTC
Thanks, Daragh
Hi Thomas,
Thanks, Daragh
I have this specific problem and I cant see the attached workspace, nor I find the linked articles helpful enough. Furthermore, I’m wondering that if a simple LAS reader to Cesium 3D tiles writer solution is not working, why does the software even let me run this workflow without any errors? I’m clearly getting some .pnts output with decent file size so what is this then if it’s not readable Cesium output???
featuremichael
Forum|alt.badge.img+9
Thanks, Daragh
Hi Thomas,
Thanks, Daragh
Thats the solution - >
What can the Cesium 3D Tiles Writer
support in the output data? →
Geometry Support
Geometry
Supported?
aggregate yes
circles
no
circular arc
no
donut polygon
no
elliptical arc
no
ellipses
no
line
no
none
yes
point
no
point cloud
no
polygon
no
raster
no
solid
yes
surface
yes
text
no
z values
yes
