Buffer left/right only
  • Nov 14, 2013 11:00 PM UTC
  • 10 replies
  • 894 views
michael
I'd like to buffer only one side of a line. According to the FMEpedia articles below, in FME 2012 and later the Bufferer transformer should have this as an option. I'm using FME 2013 sp4 (13547) and the transformer doesn't have it as an option. Am I missing something?
http://fmepedia.safe.com/articles/Samples_and_Demos/Buffer-On-Left-or-Right-Side-Only
http://fmepedia.safe.com/articles/FAQ/Whats-Great-2012
I did find the MultiBufferer from the FME Store but I can't get it to output a polygon, just a line that is offset the distance I wish the buffer to be.
Michael
Look up the custom transformer "MultiBufferer."  If you have FME 2012+ and you start typing it, the custom transformers will appear in the list on the canvas.
If it's not already downloaded, it will connect to the FME store and download it (less than a second) and add it to your workbench.
Then you'll have the option of selecting left or right only, in addition to other options.
  • Nov 15, 2013 8:07 AM UTC
it might also be possible to accomplish something similar using the OffsetCurveGenerator before the Buffferer.
David
  • Nov 15, 2013 2:31 PM UTC
Hi Michael,
This is an experimental workflow. If the line has self intersections, it doesn't work. A certain improvement will be required...
Takashi
  • Nov 15, 2013 3:52 PM UTC
... the second SpatialFilter is not necessary. The first one outputs right side polygons to FAILED port.
  • Nov 18, 2013 9:30 AM UTC
Here is the "official" solution from Safe:
Haven't compared it to the one by Takashi, though...
David
  • Nov 18, 2013 12:58 PM UTC
Yeah, I remember old Bufferer indeed has options LEFT_SIDE_ONLY, RIGHT_SIDE_ONLY etc., but the current Bufferer (Version 11) doesn't have those options. Where have they gone???
  • Nov 18, 2013 1:05 PM UTC
Indeed. It would be nice if someone from Safe could chime in on this matter :-)
gio
Forum|alt.badge.img+15
  • Nov 29, 2013 10:20 AM UTC
u can always offset the line to a half of the desired left/right buffer.
Then buffer the offsetted line with this same number.
Assuming the offsetter has a left/right choice left in FME2013...lol
  • Nov 30, 2013 6:22 AM UTC
Hi Gio,
No, the Offsetter of FME 2013 has not such options - left / right. But you can use the OffsetCurveGenerator transformer to perform your approach. Although a small gap between the original line and resultant polygon may occur at a bend of the line, if such a gap is allowable, I think your approach is very effective :-)
Takashi
rome
Participant
  • Participant
  • Apr 3, 2023 9:24 AM UTC
Hello everyone,
I am using FME 2020.2 and I would like to do a single side buffer (as it exists on QGIS) with line. The line's width is in an attribute.
According the conversation and what I have read that option was possible in the old fme version. But on my version this option is still not available.
I have tried to read the official answer from Safe posted by Mickael and david_r but the articles don't seem still available.
The "MultiBufferer" doesn't work properly in my case. It creates only lines around the polygon like "OffsetCurveGenerator".
I have tried the method proposed by gio but I have angle, start and end effect.
Do you know if I have missed a better method to create that kind of polygone ?
Thank you for your help
