Breaking linear feature at Particular coordinate
  • March 14, 2013
  • 30 views
Hi All,
I have a requirement of exporting Smallworld data into shape files, in that a challenging task is to break the linear feature at particular coordinates. I have the coordinates where i need to break in linear feature. Please suggest how I need to break the linear feature at that particular coordinates.
Thanks,
Seshu
kathyross
Participant
Forum|alt.badge.img+9
  • Participant
  • March 15, 2013
The PointOnLineOverlayer is designed to do this particular function.
You can translate your coordinate list to points via the 2DPointReplacer.
i.e.:
  1. Read in your list of coordinates
  2. Pass them into a 2DPointReplacer
  3. Set up a CoordinateSystemSetter if necessary
  4. Pass the new points into a PointOnLineOverlayer via the Point port
  5. Pass your lines into the same PointOnLineOverlayer via the Line port
  6. Attach a visualiser to the output Line port.
