Hello, I have a File Geodatabase Feature Class that has a field with people's names in the format "First Last". I have another spreadsheet with the people's Last names in one field, and their Active Directory usernames in another field. I need to get the names matched up with their Active Directory usernames as well as possible. What would be the best transformer to use to join these to tables using something similar to a "Like" or "Contains" query to get an output feature class with the usernames?
The FeatureMerger doesn't allow you to use LIKE queries as far as I can tell.
For example, say the Feature Class "Fred Johnson" in the name field, and the other table just has Johnson, I would need a Transformer and Query that joins those two and outputs a new feature class with the username.
