AutoCAD Map3d Expose Misc Attributes
  • Feb 18, 2018 7:52 PM UTC
  • 70 views
How do I expose (or what Format Attributes contains the info) the AutoCAD Map 3D Misc data "Annotative", "Block Unit" and "Unit Factor" so that it appears with the OD and other attributes I exposed on the Reader? Thanks.
daveatsafe
Forum|alt.badge.img+24
  • Feb 19, 2018 5:39 PM UTC
Hi @gobucks02,
Would you mind sending a sample of your AutoCAD data? This will help me find the existing attributes (if they exist) or create an enhancement request for development team (if they don't). If you don't want to make the data public, please send it to support@safe.com, Attn. Dave.
franco69
Forum|alt.badge.img+11
  • May 11, 2020 9:34 AM UTC
Hi @gobucks02,
was there any solution for that?
i have the same problem with ACAD Misc attributes
Greetz
Franco
