AutoCAD Map 3D write FDO connection
  • Apr 4, 2023 9:56 AM UTC
  • 79 views
aaaaaron
Is it possible to write an AutoCAD Map 3D dwg with an attached FDO connection?
I have a library of predefined .layer files containing the connection prepared.
saraatsafe
Forum|alt.badge.img+13
  • Apr 6, 2023 9:05 PM UTC
Hi @aaaaaron​, yes, you can add an FDO connection in AutoCAD to FME, which would allow you to connect to any FME supported data (it will show as an underlay in AutoCAD). As per our Providers Notes, please ensure that you're using the same platform (ie, 64-bit AutoCAD with 64-bit FME).
I hope this helps and let me know if you have any questions!
