AutoCAD Block Attributes to Point in FME
davidlee
Forum|alt.badge.img+7
I have 2 DWG files are working with FME. How to FME transform automatically Block attributes to point (Block attributes in DWG file and tags in Microstation)
File 1: FME transform automatically block to point with attributes
image.pngorginal file 1:
File 2: its not, FME is not transform block to point automatically
imageOriginal file 2:
imageHow do i get the point with the attributes of block attributes like file 1 ?
By the way with these 2 files i don't use "Preserve insert points" in FME
Best answer by featuremichael
Don't use "explode Blocks into" ;) Then you will get the insert points of the block and all the information to the point (from the block featuer)
gisgeekpro
Forum|alt.badge.img+4
  • June 16, 2023
Have you tried using the TextPropertyExtractor. With this transformer you can extract the text and store it as an attribute.
featuremichael
Forum|alt.badge.img+8
davidlee
  • June 20, 2023
Oh yeah, it's working ! Thank you so much!
davidlee
  • June 20, 2023
It's not working perfectly, I want to extract Blocks from CAD as Points with their attribute at the beginning.
featuremichael
You're welcome. ;)
