Attribute Validation without AttributeValidator (integer regex)
  • June 30, 2017
  • 61 views
I am using FME Desktop 2015.1 and need to test an attribute field for integer status.
passes are any whole number including;
zero
negative numbers where prefixed with "-"
positive numbers where NOT prefixed with "-"
In the absence of having attributeValidator (2016) can anyone advise me of the correct regex string?
Does ^(\\-)?\\d+$ look correct?
Thanks in advance,
Rob
Forum|alt.badge.img+53
  • June 30, 2017
Have you looked at the attributeclassifier, you can test for integer with this in 2015
  • June 30, 2017
Hi @egomm
Thanks very much that was exactly what I was looking for!
Regards,
Rob
