Assistance needed converting Lines to Polygons Using AreaBuilder
nstem
Participant
Good afternoon, I am extremely new to FME so apologies in advance if my question comes across as exceedingly simple or unnecessary. Anyways, I am attempting to convert a set of line features that originated in AutoCAD into a GIS formatted polygon layer. To start, I cleaned the layer as best as I could and performed snapping within QGIS. I then have tried using AreaBuilder in combination with other transformers such as LineCloser to obtain a set of polygons, but the output so far has been less than ideal. I have also experimented with Snapper and some other transformers such as LineExtender but those have introduced new errors that then lead to no output from AreaBuilder. Below I have attached an image of my workspace currently, as well as an image of the current output I am receiving. I will also attach a sample of the dataset I am working from! My conclusions are that LineCloser is causing the issue which leads to these slivers and polygons outside of the scope of the data, however I am not sure where to begin fixing it currently. I know I am most likely going to need many more transformers to accomplish this task, but I am at loss on where to start/what order to put said transformers in. Any assistance or guidance would be greatly appreciated. Thanks!
DanAtSafe
Forum|alt.badge.img+18
  • June 30, 2025
Hi ​@nstem There are gaps in your lines which are best solved by a Snapper (with segment snapping).
The LineCloser will add a segment between the first and last vertices of a single line.  Also, your units are decimal degrees so ideally you could reproject your data to a local coordinate system when dealing with topological issues.  I’ve put a TopologyBuilder in my workspace to check for dangling nodes.
  • July 1, 2025
Hi ​@nstem ,
I tried using Intersector instead of TopologyBuilder, and got a bit different result as shown below.
In my observation, there are some collinear edges in the resulting edges by the TopologyBuilder whereas the Intersector removes those collinear edges by default. I think this is the reason for the difference.
@DanAtSafe , could you please check this?
DanAtSafe
  • July 1, 2025
@takashi The TopologyBuilder seems to copy and reverse all edges and some aren’t getting cleaned up.  I’ve filed FMEENGINE-87258 about this.
DanAtSafe
  • July 25, 2025
@takashi Yes, that’s the reason for the difference - the Intersector does not separate collinear segments by default.  If you change that parameter to ‘Yes’ then the results from the Intersector and the TopologyBuilder will be identical.
Should the option to merge collinear segments be added to the TopologyBuilder?
  • July 26, 2025
@DanAtSafe ,
Thanke you for your description.
In my personal opinion, it's not essential to add the option to merge colliner segments to TopologyBuilder, but it would be better if some description regarding how collinear edges are treated could be added in the Help of TopologyBuilder.
