assign new attribute value
  • June 4, 2015
  • 80 views
I want to assign value to attribute A based on the value of attribute B.
e.g.
attribute_A     attribute_B
   1                   type1
   1                   type1
   3                   type3
...9                   type9
I know the attributeValueAssigner can do the job. But I have to type all the unique source value (here the values in attribute B). Is there a way to query all the unique values of attribute B. And then assign related value to attribute A?
Best answer by takashi
I got it. I would use the DuplicateRemover to get unique values of the attribute_B, and write them into an external table. e.g. csv.
Edit the table manually to define corresponding values (A) for each value (B); and then, merge the A values read from the table to the source data with FeatureMerger or Joiner, using B value as the join key.
  • June 4, 2015
If the requirement is to extract the digits part from the attribute_B, the StringSearcher with this setting might help you.
Search In: attribute_B
Regular Expression: \\d+
Matched Result Attribute: attribute_A
The regular expression "\\d+" matches with one or more consecutive digits, and the transformer assigns the matched part to the attribute specified in the "Matched Result Attribute" parameter.
Takashi
  • June 4, 2015
Thanks. But that's not what I need. My example just gives the wrong impression.Sorry for that.
I need for instance, type1 -> 133,  type2 -> 343, etc. Of course, after I can get the unique values from attribute B, I need to manually assign new values to those unique values. Then apply them to the attribute A of all the features.
  • June 4, 2015
