ArcGIS Dice like transformer in FME?
  • Sep 28, 2018 6:36 PM UTC
  • 5 replies
  • 83 views
Right now I am using a python runner transformer to run the arcpy dice function but was wondering if there is an easier way to limit the number of vertices?
stalknecht
Forum|alt.badge.img+22
  • Sep 28, 2018 7:58 PM UTC
You can use the Densifier to add or remove vertices. I think the Generalizer is your best option.
That looks like it only adds vertices to an existing feature.
stalknecht
  • Sep 28, 2018 8:33 PM UTC
Take a look at the Generalizer and the VertexRemover
Also the SherbendGeneralizer, but it only works with polylines, so you would have to convert your polygons first (GeometryCoercer).
basm
Forum|alt.badge.img+3
  • Jan 31, 2020 12:56 AM UTC
Any further recommendation or improvement on dicing in FME ?
mark2atsafe
Forum|alt.badge.img+59
If I understand correctly, the Chopper transformer is likely what you need. If it is, please do let me know and I'll get the documentation team to add "dice" and "dicing" as keywords - or maybe have the developers add it as an alias - so it's easier to find this transformer.
