Anyone know what the RegEx expression would be ...?
  • Apr 7, 2020 6:14 PM UTC
  • 20 replies
  • 210 views
chris.taylor
Participant
I am trying to get all of the Characters in a string that occur before the following " /" (thats a space followed by a /). Here is the catch there could be spaces and / before the occurance of the " /" and I want to keep those in the found string.
I was trying to use the stringSearch and do this in one step (I was able to do this in 2 steps by first stringReplace the " /" with a character I knew would not appear and then doing a stringsearch but this should be doable in one step with the correct regEx expression)
Here are examples
123ABD / 99 - "123ABD" would be found
123/ABD / 99 - "123/ABD" would be found
123% ABD/99 / 789 - "123% ABD/99" would be found
123 / 456 / 789 - "123" would be found
hopefully this makes it clear
Thx
in advance to you RegEx wizards out there...
Best answer by gio
@chris.taylor
Hi. Here is one that actually does the job. That is, it also gets the last one right.
1586283947463
where the regex is: ^(.+)\\s/\\s
and the result is returned as the list:
_substring{0}.part 123 / 456
FME 2020: regexExample.fmw
Forum|alt.badge.img+54
  • Apr 7, 2020 6:27 PM UTC
You  could do this in an attributecreator
@Left(@Value(string),@FindRegEx(@Value(string),\s/))
This finds the position of the first " /", then uses that position to get the left characters up until that point
chris.taylor
Participant
  • Participant
  • Apr 7, 2020 11:34 PM UTC
1586283947463
this fails on the example "123 / 456 / 789" it returned "123 / 456" it should only return "123"
chris.taylor
Participant
  • Participant
1586283947463
but still way closer than I ever got :)
chris.taylor
Participant
  • Participant
  • Apr 7, 2020 11:36 PM UTC
thanks not the way I was thinking to do it but it does work
  • Apr 8, 2020 4:00 AM UTC
Hi @chris.taylor, there should be several solutions. This regex is one of them, which matches one or more consecutive characters before the first "<space>/".
arnold_bijlsma
Forum|alt.badge.img+16
RegEx is by default 'greedy' (finding the longest match possible), and you need to make it 'lazy' (finding the shortest match possible) by adding a question mark after the plus (also shown in @takashi's answer):
^(.+?)\s/\s
  • Apr 8, 2020 2:02 PM UTC
In an AttributeCreator/Manager you could also replace the " /" and everything to the end of the string with nothing to get the same result
@ReplaceRegEx(@Value(input),\s\/.*$,"")
chris.taylor
Participant
  • Participant
  • Apr 8, 2020 3:48 PM UTC
thanks I figured there were multiple ways of doing this but I stink at Regex expressions so I was interested in learning how it would be done that way...   I have several ways now thanks
chris.taylor
Participant
  • Participant
  • Apr 8, 2020 3:49 PM UTC
1586283947463
thanks Ill check that out today
gio
Forum|alt.badge.img+15
  • Apr 8, 2020 4:17 PM UTC
@chris.taylor
arnold_bijlsma
@chris.taylor
Have you actually tried it in a StringSearcher, because it fails on all 4 examples for me.
stringsearcherregex.fmw
  • Apr 8, 2020 5:06 PM UTC
You have extra spaces on the end of your regular expression.
chris.taylor
Participant
  • Participant
  • Apr 8, 2020 5:22 PM UTC
^(.+?)\s/\s   so this is including the " / " is there a way to return only the characters before the " / " ?
arnold_bijlsma
You're right! Doh!!
chris.taylor
Participant
  • Participant
  • Apr 8, 2020 5:24 PM UTC
@chris.taylor
BINGO this does exactly what I was after but I havr to admit I have no clue as to why...   Ill do some research on this expression ... thanks
arnold_bijlsma
You need to use the _substring list that @markatsafe is showing and then take your value as the first element from that list, i.e. _substring{0}.part
chris.taylor
Participant
  • Participant
  • Apr 8, 2020 5:29 PM UTC
wait no it doesn't get it right   it still shows "123 / 456"  this one should return 123
123 / 456 / 789    --- 123 / 456
123% ABD/99 / 789   ----    123% ABD/99
123/ABD / 99    ---    123/ABD
123ABD / 99    ---  123ABD
but this worked (just added the lazy ? in the first part as was suggested in one of the other comments):
string    _creation_instance    _first_match
123 / 456 / 789    0    123
123% ABD/99 / 789    0    123% ABD
123/ABD / 99    0    123
123ABD / 99    0    123ABD
chris.taylor
Participant
  • Participant
  • Apr 8, 2020 5:31 PM UTC
123/ABD / 99 0 123
wait you diid have that ? in there I must have missed it when I typed it in the first time..... YOU got it problem solved thanks
@chris.taylor this is a great regex site f understanding what each part of a regex expression is doing.: https://regexr.com/
