Anyone know if there is a way to only expose the selected features from ArcGIS Pro to the FME ArcGIS Portal Feature Service when using the interoperability extension?
  • Nov 9, 2023 1:17 PM UTC
  • 46 views
I am in the process of creating an FME script to download photos as attachments features in ArcGIS Portal using the FME ArcGIS Portal Feature Service.
The script runs fine from the ArcGIS Pro application using the interoperability extension.
The only problem is that images from all the features is downloaded, even if only some is selected in ArcGIS Pro.
kailinatsafe
Forum|alt.badge.img+24
Hello @haroe​, thanks for posting! I think in order to extract certain features from a feature class or feature service you can use the 'Constraint' parameters on the portal reader feature type. Let me know if you're still having issues reading the features of interest after applying some of those parameters. Happy to help, Kailin.
