Aggregator issues with ArcMap but works with FME
  • Jun 12, 2020 1:49 PM UTC
  • 38 views
Hi all,
I have been trying to put together some GIS data we have that was in a list format. When i use FME and check with the inspector this looks fine, data is what i am after. The same when i produce this in QGIS, looks fine.
When using arcmap, i seem to see some of the shapes are not getting the same symbology and just displays the outline of the shape. Does anyone know why this might be the case and is there a solution to this issue?
fmelizard
Forum|alt.badge.img+22
  • Jun 15, 2020 3:52 PM UTC
Hi @gisrewards Check to see if the aggregate contains identical overlapping shapes. ArcMap might be reading it as a donut with identical shells.
