Adding SAP HANA ngdbc.jar to FME Server config
  • Mar 8, 2018 10:31 PM UTC
  • 184 views
scyphers
Participant
Forum|alt.badge.img+5
How does one add the ngdbc.jar SAP HANA driver to FME Server and update the FME Server Config?
I have tried to publish a script reading tables using both Native HANA reader and the generic JDBC reader connection and the script will not run. The error is java.sql.SQLException: No suitable driver found
I presume the ngdbc.jar file needs to be here, and FMEServer restarted?
C:\\$apps\\FMEServer\\Server\\lib
Can someone please assist me in setting up the drivers and subsequent CommonConfig changes on FME Server?
Best answer by richardatsafe
Hi @scyphers,
Yes the jar usually goes on the share and server does need to be restarted, but the jars usually need to be placed here: <FMEServerSystemShare>/Resources/engine/Plugins/Java so it can be shared with all the engines. Please have a look at the document below.
https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_ReadersWriters/jdbc/getting_started_jdbc.htm
Thanks,
Richard
richardatsafe
Forum|alt.badge.img+11
  • Mar 9, 2018 11:40 PM UTC
Hi @scyphers,
Thanks,
Richard
scyphers
Participant
  • Participant
  • Mar 13, 2018 11:38 PM UTC
Hi @scyphers,
Thanks,
Richard
Thank you Richard, apologies I had not checked-in in a few days. I did look around in the Docs for JDBC but i clearly did a Steve Look. I will read the docs page at the link and have deposited the driver in the plugins folder described above. I will get it working now.
  • Apr 20, 2018 2:22 PM UTC
Hi There,
Thank u For sharing this unique article. Definitely a life saver.
Need your help to validate if solution recommended by SUSE support to upgrade the existing kernel - 4.4.21-69.1 ( SP2-Nov-2016 ) to latest available kernel - 4.4.114-92.67.1 ( Feb-27-2018 ) for SLES 12.2 SAP Application SP2 is compatible / supported for on Hyper-V VMs.called?Appreciate your effort for making such useful blogs and helping the community.
Many Thanks,
Irene Hynes
