Add value to create new (compounded?) value
  • Aug 3, 2017 3:05 PM UTC
  • 112 views
conch
Forum|alt.badge.img+4
Unsure if compounded is the right term but anyway....I am trying to calculate a new attribute based on existing values - usually easy to do - but in this case the expression must reference each subsequent attribute value in an original attribute. Best explained by the graphic below:
'StaticValue' is the original value and 'CompoundedValue' is the attribute I want to create. The first value will be unchanged but each subsequent value in the 'CompoundedValue' attribute must reflect the corresponding 'StaticValue' value.
StaticValueCompoundedValue30030020320-50270-4023016039035425
Can I do a 'circular' reference like this in FME?
Best answer by conch
Nevermind...I solved it by using the 'SumAttribute' function on the StatsCalculator and outputting values via the 'Cumulative' port. Easy peasy :)
conch
StaticValueCompoundedValue30030020320-5027012039080470-30440
conch
danilo_fme
Forum|alt.badge.img+58
  • Aug 3, 2017 3:13 PM UTC
Good question and solution :) @conch
