Add parameter to FME Server URL.
  • Jul 21, 2020 1:56 AM UTC
  • 97 views
timwarfe
Forum|alt.badge.img+10
Hoping someone can point me in the right direction, please.
I have a workspace published on the FME Server and I want to be able to run this with the Property Number already populated from the URL.
Thank you
Tim
kailinatsafe
Forum|alt.badge.img+24
Hello @timwarfe,
Unfortunately, this is not possible in FME Server. I found this post on the FME Community Ideas page, it seems like other users would also like to see this brought into FME Server! To help the idea gain traction - you can upvote the idea by clicking the thumbs up button (left hand side). Similarly, you add a comment on the idea to share why this would be valuable for your use case.
Hope this helps,
Kailin Opaleychuk
As a work around could you write the Council Property Number to a text file so the running of the workspace isn't dependent on a dynamic parameter?
