Add Geometry to Feature
  • Jun 22, 2015 2:20 PM UTC
  • 36 views
Hello everyone,
I want to add geometries from one feature to another and change their geometry_name.
I have a base feature "VerticalStructure" which has a list of geometries (Polygone) (part{}.VerticalStructurePart.extent). But this "VerticalStructure" also contains geometries for LightElements (part{}.VerticalStructurePart.lighting{}.LightElement.location). So I created another feature called "VerticalStructureLightElement" (Point), and set the geometry (lighting{}.LightElement.location)
After creating both geometries I thougt I could use an Aggregator to add the geometries from "VerticalStructureLightElement" to "VerticalStructure". But somehow i am stuck. I want to rename all "VerticalStructureLightElement" geometries to part{}.VerticalStructurePart.lighting{}.LightElement.location to add the lightElement geometry to every item of part{}.
I also tried the FeatureMerger, but then most geometries get lost.
Does someone know how to handle that?
Regards,
Melanie
Best answer by pratap
If this problem is not solved then could you please explain in detail
pratap
Forum|alt.badge.img+12
  • Jun 25, 2015 11:04 AM UTC
