Add attributes from Excel spreadsheet to parcel data
  • October 23, 2013
  • 57 views
I have a very long translation that takes several area layers that I need to add an attribute from an excel spreadsheet.  I have tried using an attribute creater, then attribute keeper, then feature merger with a point layer, but the attribute does not show up on my final parcel layer.  Any suggestions would be appreciated.
Thank you.
Best answer by fmelizard
There are a few issues to consider:
Does the merge take place? > can you see the attribute comming out of the merged port?
Did you add the attribute to the writers schema? > can you see a green arrow at the writer, where your new attribute is?
Hope this helps,
Itay
fmelizard
Forum|alt.badge.img+22
  • October 23, 2013
Hope this helps,
Itay
