Add Aliases to File Geodatabase
  • Nov 29, 2022 6:35 PM UTC
  • 8 replies
  • 931 views
vxn43
Forum|alt.badge.img+20
My Reader is Excel. My Writer is ESRI File Geodatabase. I use AttributeManager to rename the fields. How do I add field name aliases to the Writer in this situation?
Best answer by dustin
Working with Geodatabase Field Aliases: Altering Alias Values (safe.com) This article will walk you through the methodology.
dustin
Forum|alt.badge.img+36
  • Nov 29, 2022 6:49 PM UTC
vxn43
  • Nov 29, 2022 6:55 PM UTC
Thank you. I read this article, and it is relevant only if you are reading from a geodatabase. I am reading from an Excel file and writing to a geodatabase. Do you think I need to create a 2nd workspace that I run after I write the feature classes? this 2nd workspace would assign aliases to the feature classes using a geodatabase in the reader. I think this would work, but wondering if there is way to incorporate this workflow into a single workbench?
egge
Forum|alt.badge.img+14
  • Nov 29, 2022 7:02 PM UTC
And what do you think of the answer to this Question: How do I create an alias on an attribute in my FME workspace?
dustin
  • Nov 29, 2022 7:03 PM UTC
Check out the Advanced section of the article. It explains how to create aliases from scratch on features writing to geodatabase. In this manner, the input format won't affect your ability to write them.
vxn43
  • Nov 29, 2022 7:32 PM UTC
@egge​ and @dustin​ thank you. I read the information. I tried adding the FacilityName_alias (value = FACILITYNAME) to a new field in AttributeManager (not the Writer) and it ends up adding a new field in the feature class named "FacilityName_alias". In ArcMap I checked the field properties for FACILITYNAME, and it still shows the Field Alias as "FACILITYNAME". I would like FACILITYNAME to have the alias "FacilityName".
Alias1I think I am missing something, what could it be? thanks.
dustin
  • Nov 29, 2022 7:37 PM UTC
First, I would imagine it is case sensitive, so it needs to be FACULTYNAME_alias. The Attribute Value of FACULTYNAME_alias needs to be whatever you want the alias to be. As it is now, you are pulling the attribute value from FACULTYNAME, which I don't think is what you want.
vxn43
  • Nov 29, 2022 8:10 PM UTC
@dustin​ Apologies I must be obtuse today. You pointed me in the right direction, and I finally was able to figure it out. It works. Here is a screenshot of how to insert aliases for anyone else who may need assistance with this.
Alias2
dustin
  • Nov 29, 2022 8:11 PM UTC
Alias2
No worries, glad you got it working!
