Add a specific text as header and footer of text file
  • Oct 11, 2023 6:31 AM UTC
  • 177 views
arash_hokm
Forum|alt.badge.img+8
Hello FME Community,
I am using a 'StringConcatenator' and a 'Text Writer' to create a text file. I intend to add two separate texts as the header and footer.
Is there a way to add these texts without duplication?
Best answer by nielsgerrits
One way to do this:
  • Sampler to get a single line feature from the data features and use this feature to create the header and the footer features.
  • AttributeCreators on the header, data and footer streams with an attribute "order" with the values 1, 2 or 3.
  • Sorter to sort on the attribute order.
  • Connect to the writer.
nielsgerrits
Forum|alt.badge.img+67
  • Oct 11, 2023 7:10 AM UTC
One way to do this:
arash_hokm
  • Oct 11, 2023 8:27 AM UTC
One way to do this:
@nielsgerrits​ Thank you very much.
It worked.
