Add a custom datum definition to FME2013
  • April 23, 2013
  • 6 replies
  • 71 views
Hello,
I have to add a custom coordinate system that includes a custom datum to FME2013. I know how I can add the custom coordinate system to my file "MyCoordSysDefs.fme". Where can I add the custom datum information and how is the syntax?
Can you provide any help?
Borone
  • April 23, 2013
Hi Borone,
have you looked at this article?
David
  • April 23, 2013
Hi David,
yes, I read this article. I know, how I reference my custom coordinate system definition to a pre-defined datum definition with the parameter "DT_NAME".
But how and where can I add my custom datum?
Borone
  • April 24, 2013
Hi Borone,
check Workbench menu Help > FME Coordinate Systems to open 'FME Desktop Help', go to FME Coordinate Systems > Datums > Datum Definition page, then you can see the syntax of a datum definition. And there are some examples of 'DATUM_DEF' directives for new datum definitions in 'MyCoordSysDefs.fme'.
Takashi
  • April 24, 2013
Hi Takashi,
in my 'MyCoordSysDefs.fme' there are no examples of 'DATUM_DEF' directives!
Thank you for your advice. I found the syntax of datum definition in FME Coordinate Systems > Datums > Datum Definition.
Do you know if I can use other transformation methods beside Bursa-Wolf ('USE BURSA') except using grids?
Borone
fmelizard
Forum|alt.badge.img+22
  • April 25, 2013
Hi Borone,
In here you can find all the use type available for datum definitions.
Hope this helps
  • April 25, 2013
Hi Itay and Takashi,
thank you for your advices. I've got the right information for the definitions.
Borone
