Accessing PL/SQL variable in insert statement using SQLExecuter.
Hello,
I am trying to execute below plsql statement using SQLExecuter.
But the declared variable (mId) is not populating select statement "mId" value.
DECLARE mId number;
BEGIN
  select MAX (id) INTO maxId from @Value(table);
  insert into @Value(table) (ID,@Value(columnsStr)) VALUES (mId, @Value(ValueStr));
END;
FME_SQL_DELIMITER /
Expected output during execution: insert into table1 (ID,name) VALUES (10, 'test');
FME Output during execution: insert into table1 (ID,name) VALUES (mId, 'test');
Thanks,
G
Best answer by david_r
Is the mixup of "maxId" and "mId" above a typo?
You could also simplify it to a single statement:
VALUES ((select MAX (id) from @Value(table)), @Value(ValueStr))
That way you don't need to use PLSQL.
  • April 1, 2022
@david_r​ Thanks. sorry for the typo. It works
