A tool in FME to remove duplicates,
jamal
Forum|alt.badge.img+5
I couldn’t figure out which tool can remove duplicates. For example, in case we have two lines that are identical (one on top of another), then which tools can remove this duplicate?
For example, in the screenshot below we have 4 lines that are identical, then how to remove three of them and to leave one?
Thank you
Best
Jamal
Best answer by redgeographics
jamal wrote:
Not sure which tool can remove the duplicates shown in the screenshot below
Line#3 and line #4 are duplicated in the marked part
Clip_90
Clip_89
If they match exactly I'd try the Intersector or LineOnLineOverlayer. Both have the option to generate a list with the attributes of the original overlapping features so you can work with those.
So basically, in your screenshot, you can remove the Chopper and Matcher and it should work.
  • September 3, 2014
The Matcher transformer would do this for you. If you take the output of the SingleMatched and NotMatched ports then you would - in effect - be dropping duplicates.
Hope this helps
Regards
Mark
Mark Ireland
Product Evangelist
Safe Software Inc
jamal
  • September 3, 2014
Many thanks Mark for the help,
It appears that the “matcher” couldn’t catch the duplicates. It keeps the original number as is despite the fact that there are a plenty of duplicates.
What might be the issue here?
The dwg file:
http://www.mediafire.com/download/xhrc6kchbacx0s0/Parcels.dwg
  • September 4, 2014
Hi Jamal,
Have a look at the "Lenient Geometry Matching" parameter in the Matcher.
Takashi
jamal
  • September 4, 2014
Thanks Takashi,
I couldn’t figure out precisely how the matcher works and how does it remove the duplicates.
1. I wanted to remove the duplicates
2. And then to convert lines to polygons.
This doesn’t appear to work with the “matcher” and “GeometryCoercer”.
The polygons fail to be written in the polygon feature class?
  • September 4, 2014
The Matcher seems to work properly. The problem is on the GeometryCoercer, it will not transform lines into polygons. Consider using the AreaBuilder instead.
jamal
  • September 4, 2014
Many thanks Mark and Takashi for the help,
It appears to work fine now as I have adjusted the workbench based on your valuable comments.
  • March 15, 2018
Hope this helps
Regards
Mark
Mark Ireland
Product Evangelist
Safe Software Inc
It would be nice if the transformer had a port for "matched except one" so you can remove all but one duplicate record easily. Currently, if I understand the transformer, you have to delete the Matched and then add back in the SingleMatched. Matched=SingleMatched+MISSING port.
jamal
  • November 9, 2021
Clip_90
Clip_89
Forum|alt.badge.img+50
  • November 9, 2021
Clip_90
Clip_89
kailinatsafe
Forum|alt.badge.img+21
Clip_90
Clip_89
Hello @jamal​ , this article has a few alernative approaches, it may be worth taking a peek! Data QA: Identifying Duplicate Features with FME.
jamal
  • November 17, 2021
Right. Intersector or LineOnLineOverlay can remove the duplicates as per the screenshot below. The duplicate segment gets in a separate object. All can be joined with linecombiner tool
Clip_1140
Clip_1141
