12DXML reader string geometries not extracting correctly
I am trying to convert 12Dxml string data to other datasets but really struggling with the way the geometries are being read by the 12Dxml reader.
I am not trying to do anything fancy just read the file.
from 12Da file
from FME
I am willing to share 12dXML via support as this contains project specific data.
virtualcitymatt
Forum|alt.badge.img+39
Are you running FME 2020? I'd be curious to see if the new XMLfromXSD reader works for you here.
Have you also just tried the XML reader to see if there is a difference to the 12dXML reader?
Could there be a difference in the version of 12dXML?
If not then this is likely a case for support :-/.
i will have a look, this is just simple string data so not sure why the 12Dxml reader shouldn't pick up the geometries and relationships correctly
