The equivalent tool to “Pivot Table” of ArcGIS in FME,
The equivalent tool to “pivot table” of ArcGIS in FME,
I couldn’t figure out which tool is equivalent to “pivot table” of ArcGIS in FME. I have a layer and I want to rearrange the attribute table in a specific way
The following picture shows my need
when i use the pivot table tool the table is look like this
Thanks in advance
Best
  • June 29, 2015
deja vu. (https://knowledge.safe.com/CommunityAnswers?id=906a0000000dBuLAAU)
Change the attribute name "Percentage" to the VALUE of "ABC"; aggregate features grouping by "Name"; expose the new attribute names.
Alternatively, the AttributeCreator can be used instead of the BulkAttributeRenamer.
Finally remove unnecessary attributes with the AttributeRemover.
Takashi
  • June 29, 2015
Thanks  Takashi,
but is there any method to let the FME create new fields with new names based on the entries of a colum in attribute table
to be like this
best
  • June 29, 2015
The same. Just remove the Aggregator, and add a NullAttributeMapper after the AttributeExposer to assign 0 to missing attributes.
  • June 29, 2015
Hi
just an untested idea, but is it possible that the AttributePivoter could be helpful here?
David
  • June 29, 2015
I've never used the AttributePivoter. Now tried ... then it worked :)
  • June 30, 2015
yup, the AttributePivoter is a little bit tricky. Hope this works as expected.
  • June 30, 2015
Thanks a lot Takashi it works fine
  • October 7, 2019
@takashi thanks for the answer! I have the same problem.
How can I keep the selected attributes which I have got after AttributePivoter?
I don't know the names in advance it's a dynamic list of attributes.
salvaleonrp
Forum|alt.badge.img+16
  • January 21, 2020
Is there an alternative to AttributePivoter? I have a table that I needed to transpose and after the pivot it has 500+ attributes to expose. Occasionally, the schema of the table has to be changed and the attributes I need to expose are now changed, So now I have to import the updates into my work bench.
jovitaatsafe
Forum|alt.badge.img+11
Hi @salvaleonrp,
This Q&A thread appears to be from quite a few years ago, would you be open to posting a new question for better visibility? It's easy to overlook new comments on an old post and at a glance this one looks like it's already solved.
In the meantime have you already taken a look at our Pivot Tables and FME article and Manipulation of Tabular Data? Both contain examples of the transformer that may hopefully be helpful. Thanks!
