Archived
Junction Transformer
Related products:FME Form
nielsgerrits
Would be nice if the shape of the Junction could be changed from the dot to a regular Transformer. I used the AttributeRemover as Junction before they were introduced. (I still do, but this can be tricky...)
Having a hard time to click / select the tiny junctions and can't get used to the different look. I know the workarounds, like a Custom Transformer, but it might help others as well.
fmelizard
Forum|alt.badge.img+18
  • May 30, 2018
The Junction is just a Cloner with the # of clones set to 1. So you could easily go back to use Cloner maybe?
fmeta
  • May 30, 2018
How about increasing the size of the junction points? (Optionally)
jkr_wrk
Forum|alt.badge.img+29
  • May 30, 2018
I like the idea of using a Cloner instead of a AttributeRemover because it is very visible that it is set to 1 when input and output amount is the same. Whereas you don't know what an AttributeRemover is doing. But the Cloner creates an attribute by default and has a <Rejected> port which makes it larger.
So I would prefer a Junction with a bigger size so it is easier to click on.
LizAtSafe
Forum|alt.badge.img+15
  • February 8, 2024
Updated idea statusGathering InterestArchived
Idea merged into:
ecthelion
All the votes from this idea have been transferred.
