WCS Sentinel hub not working with featurereader
michiedem
Forum|alt.badge.img+7
I used the sentinel hub dashboard to create a WCS-link. This link works fine in Qgis, however in FME I can not get it to work.
I am using FME 2020.0.0.1
When I use the feature reader I can select the coverage (raster band) in the parameters setting, but all other settings I try return an error:
Failed to retrieve feature types.
<WCS> An error has occured while processing the WCS DescribeCoverage document: 'supportedInterpolations'
When I try to run the workbench I get the following error:
Does anybody know how I can fix this?
Be the first to reply!
