autocad block attribute editing
  • September 8, 2014
  • 38 views
I have about 250 dwg files that all have the same block inserted in paperspace. The block has editable attributes. Am I able to use FME to change a single attribute within the block?
Thanks,
Ben
Best answer by gio
Sure,
You need ot read the correct layer to acces the relevant attribute.
If im not mistaken u should acces psvports and expose fme_attrib_info on the reader  (Format Attributes) etc.
I am assuming you are talking papaerspace blocks here.
<strong>This post is closed to further activity.</strong><br /> It may be a question with a best answer, an implemented idea, or just a post needing no comment.<br /> If you have a follow-up or related question, please <a href="https://community.safe.com/topic/new">post a new question or idea</a>.<br /> If there is a genuine update to be made, please contact us and request that the post is reopened.
gio
Forum|alt.badge.img+15
  • September 8, 2014
Sure,
