I’m using the Data Interoperability extension in ArcGIS Pro. I can’t seem to get a excel reader to add in. I’ll set the parameters, it’s not open anywhere else, it’s not password protected or anything like that, and it’s on my local system.
When I click ok to add it, fme acts like it’s trying to add it, but then just sits there and spins until it eventually times out.
What am I doing wrong? I haven’t used FME in about 7 years or so, but I used it extensively prior to that and never had this sort of issue.
