Hello,
I recently received a new fme flow 2024 from my IT department and something keeps failing when i run a large workspace(1096704 kB), i get no error but the workspace fails.This same workspace runs in fme flow 2023 without any problem.
Here are my system details,
FME FLOW 2023
System Status: 43.39 GB of disk space available in the FME temporary folder (C:\Users\Username\AppData\Local\Temp\fmeengines\{enginename}_Engine1)
System Status: 30.00 GB of physical memory available
System Status: 126.00 GB of virtual memory available
FME FLOW 2024
System Status: 65.31 GB of disk space available in the FME temporary folder (C:\Windows\TEMP\fmeengines\{enginename}_Engine2)
I have been reading around but i have not been able to pint out where the problem actually lies. How can i check for example how much memory has been allocated to an engine?Could it that i need to change the engine to use the temp folder as to a local user instead of the windows temp folder ?
Any ideas/solutions will be highly appreciated.
Regards,
Bii.
