camelCase in SpatiaLite
  • June 2, 2021
  • 44 views
jelle
Forum|alt.badge.img+22
Hi, when adding attributes to the SpatiaLite Writer, FME converts them to lowercase. However, my output needs to be in camelCase. Any ideas how to solve this? Should I raise an Idea in the Community, or is it just me?
I found this track on underscores: https://community.safe.com/s/question/0D54Q000080hThDSAU/-in-fieldname-change-to-underscore-how-to-solve
SQLite and GeoPackage (which is in fact a SQLite implementation) do not have this behaviour in FME.
jovitaatsafe
Forum|alt.badge.img+11
Hi @Jelle De Zwaef​,
It looks like this issue has been noted in the past tracked internally (FMEENGINE-60521) as an enhancement to allow for writing tables with upper or mixed case attribute names. There doesn't seem to be a timeline on it yet so it may be worth adding a new Idea to upvote to inform our product development team of your interest. I'll let you know as soon as the issue has been addressed. Is the SQLite writer a potential workaround for you in the meantime?
jelle
  • June 8, 2021
Hi @jovitaatsafe​, thank you for your answer. I currently switched to GeoPackage as a workaround. I'll post an Idea, mentioning the track number.
