I recently upgraded my FME Server (to 2020.2.4) and the unwanted file hierarchy for FileCopy output datasets in Data Download Zip files have returned! I now have an additional folder (called FILECOPY_1) in the output zip from a Data Download Service on Server. I've updated the Writers in Desktop (2020.2.4), but the edit functionality (Publish --> Edit Register Services --> More) seems to do nothing for the structure of the zip file for FileCopy outputs anymore after publishing (the old way is outlined here: https://community.safe.com/s/question/0D54Q000080hM9QSAU/how-can-i-change-the-folder-structure-returned-in-the-zip-file-from-fme-servers-data-download-service).
I this a known bug, and is there a fix please?
Many thanks!
How are the writer(s) and Data Download output folder structure configured in your case?
As shown, in my zip, I'm looking for a folder in there called 'GRIDS', and a loose xlsx file (labelled here as 'Quote') - having an empty 'Path in Zip File' worked in 2019.2, but using these settings gives me 2 folders in the Zip output; GRIDS (correct) and FILECOPY_1 (containing the Quote xlsx).
