Calculating journey times
  • November 5, 2014
  • 82 views
Hi
I have a set of origin points "origins" and a set of destination points "destinations" for which I would like to calculate the journey time between each of them (for every OD pair).
I also have network shapefile "network" that has the road centrelines which contains speed and distance attributes.
I think I need to use "shortest path finder" and weight it by the speed but is anyone able to help describe this in more detail/ suggest an alternative method to create a OD matrix with journey times and another with journey distances for each OD combination?
Thanks
Forum|alt.badge.img+19
  • November 5, 2014
I think the ShortestPathFinder is a good choice.
The transformer requires a "From-To" line (i.e. origin-destination) feature to compte a shortest path. So you will have to create every origin-destination line at first.
After reading the origin / destination points:
1) Add a CooridinateExtractor to extract x, y of each destination points.
2) Add a FeatureMerger, send the origin points to the Requestor port, the destination points to the Supplier port, and perform unconditional merging so that every destination x, y will be migrated to all the origin points.
Join On: 1 to 1 (constant)
Process Duplicate Suppliers: Yes
Duplicate Supplier List: _dest
3) Connect a ListExploder to the Merged port of the FeatureMerger, explode the features on the "_dest{}".
4) Add a VertexCreator to add destination coordinate to every origin point. i.e. transform the origin points into From-To (origin-destination) lines based on the destination x, y value.
You can then send the lines to the ShortestPathFinder to get shortest path for each origin-destination pair.
Takashi
gio
Forum|alt.badge.img+15
  • November 6, 2014
A unconditional merger is very usefull to have.
You can use the one in the fme-store.
Or build one yourself, wich is very easy.
I did, so i can merge more requestors simultaneously and to have tha ability to group during the merger.
Creting a network is also easy with fme by using topologybuilder(s) and NetworkFloworientors etc.
  • November 6, 2014
thanks very much everyone! :)
