Oracle Spatial Object and Synonyms
  • November 24, 2014
  • 4 views
Hello,
I am trying to view Oracle Spatial data in FME Data Inspector. I need to view spatial data from a synonym but when try to retrieve table list I am getting only tables not the synonyms.
Is this expected behaviour of FME? Is there any way around to view data from synonym?
Cheers,
John
Best answer by david_r
did you already add the metadata entry for the synonym?
See http://fmepedia.safe.com/articles/Samples_and_Demos/Oracle-Spatial-Object#heading_toc_j_3
David
  • November 24, 2014
David
  • November 24, 2014
Thanks David. Don't know how I forgot. :)
